Time Before: 0.02158 seconds
Time After: 0.02614 seconds
Time Taken: 0.00457 seconds
Time Before: 0.02623 seconds
Time After: 0.02674 seconds
Time Before: 0.02746 seconds
Time After: 0.02798 seconds
Time Before: 0.02888 seconds
Time After: 0.03179 seconds
Time Taken: 0.00291 seconds
Time Before: 0.02806 seconds
Time After: 0.03587 seconds
Time Taken: 0.00781 seconds
Time Before: 0.04224 seconds
Time After: 0.04256 seconds
Time Before: 0.04519 seconds
Time After: 0.04660 seconds
Time Before: 0.04139 seconds
Time After: 0.04689 seconds
Time Taken: 0.00550 seconds
Time Before: 0.08391 seconds
Time After: 0.08411 seconds
Time Before: 0.42710 seconds
Time After: 0.42895 seconds
Time Taken: 0.00185 seconds
End call of global.php: 0.43171882629395
Time Before: 0.44030 seconds
Time After: 0.44047 seconds
Time Before: 0.44326 seconds
Time After: 0.44510 seconds
SET lastactivity = 1789032512, location = '/forums/private.php?do=newpm&explain=1&u=7387'
Time Before: 0.46647 seconds
Time After: 0.46675 seconds
Memory Before: 4,911.164 KB
Memory After: 4,911.383 KB
Page generated in 0.46518087387085 seconds with 9 queries, spending 0.01001238822937 doing MySQL queries and 0.45516848564148 doing PHP things.
