Time Before: 0.00150 seconds
Time After: 0.00202 seconds
Time Before: 0.00209 seconds
Time After: 0.00256 seconds
Time Before: 0.00278 seconds
Time After: 0.00291 seconds
Time Before: 0.00355 seconds
Time After: 0.00585 seconds
Time Taken: 0.00230 seconds
Time Before: 0.00296 seconds
Time After: 0.00925 seconds
Time Taken: 0.00629 seconds
Time Before: 0.01107 seconds
Time After: 0.01145 seconds
Time Before: 0.01276 seconds
Time After: 0.01398 seconds
Time Before: 0.01042 seconds
Time After: 0.01415 seconds
Time Taken: 0.00373 seconds
Time Before: 0.01923 seconds
Time After: 0.01942 seconds
Time Before: 0.02135 seconds
Time After: 0.02261 seconds
End call of global.php: 0.024236917495728
Time Before: 0.02541 seconds
Time After: 0.02560 seconds
Time Before: 0.02763 seconds
Time After: 0.02905 seconds
SET lastactivity = 1773297406, location = '/forums/private.php?do=newpm&explain=1&u=73894'
Time Before: 0.04138 seconds
Time After: 0.04176 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.040502071380615 seconds with 9 queries, spending 0.0079276561737061 doing MySQL queries and 0.032574415206909 doing PHP things.
