Time Before: 0.02209 seconds
Time After: 0.02727 seconds
Time Taken: 0.00518 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.02739 seconds
Time After: 0.02785 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.02811 seconds
Time After: 0.02829 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.02913 seconds
Time After: 0.03178 seconds
Time Taken: 0.00265 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.02835 seconds
Time After: 0.03604 seconds
Time Taken: 0.00769 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.04363 seconds
Time After: 0.04400 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.04526 seconds
Time After: 0.04644 seconds
Time Taken: 0.00118 seconds
Memory Before: 2,908.320 KB
Memory After: 2,908.180 KB
Time Before: 0.04282 seconds
Time After: 0.04668 seconds
Time Taken: 0.00386 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.250 KB
Memory Used: 132.648 KB
Time Before: 0.07016 seconds
Time After: 0.07034 seconds
Memory Before: 3,655.805 KB
Memory After: 3,656.320 KB
Time Before: 0.34863 seconds
Time After: 0.35022 seconds
Time Taken: 0.00159 seconds
Memory Before: 4,133.352 KB
Memory After: 4,133.945 KB
Time Before: 0.37458 seconds
Time After: 0.37476 seconds
Memory Before: 5,197.547 KB
Memory After: 5,325.891 KB
Time Before: 0.38082 seconds
Time After: 0.38233 seconds
Time Taken: 0.00151 seconds
Memory Before: 5,481.227 KB
Memory After: 5,610.828 KB
UPDATE session SET lastactivity = 1773363335, location = '/forums/private.php?do=newpm&explain=1&u=7392', badlocation = 1 WHERE sessionhash = 'eaa8a3ac54cff5a66f956999e9bca4a9'
Time Before: 0.40152 seconds
Time After: 0.40187 seconds
Memory Before: 5,998.008 KB
Memory After: 5,998.219 KB
