Time Before: 0.01323 seconds
Time After: 0.01837 seconds
Time Taken: 0.00514 seconds
Time Before: 0.01849 seconds
Time After: 0.01889 seconds
Time Before: 0.01922 seconds
Time After: 0.01933 seconds
Time Before: 0.02022 seconds
Time After: 0.02248 seconds
Time Taken: 0.00225 seconds
Time Before: 0.01941 seconds
Time After: 0.02807 seconds
Time Taken: 0.00866 seconds
Time Before: 0.03610 seconds
Time After: 0.03633 seconds
Time Before: 0.03901 seconds
Time After: 0.04024 seconds
Time Before: 0.03530 seconds
Time After: 0.04044 seconds
Time Before: 0.07406 seconds
Time After: 0.07420 seconds
Time Before: 0.31987 seconds
Time After: 0.32132 seconds
End call of global.php: 0.32374691963196
Time Before: 0.32927 seconds
Time After: 0.32949 seconds
Time Before: 0.33211 seconds
Time After: 0.33361 seconds
SET lastactivity = 1785339811, location = '/forums/private.php?do=newpm&explain=1&u=74074', badlocation = 1
Time Before: 0.35255 seconds
Time After: 0.35357 seconds
Time Taken: 0.00102 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
Page generated in 0.35126399993896 seconds with 9 queries, spending 0.0085599422454834 doing MySQL queries and 0.34270405769348 doing PHP things.
