Time Before: 0.00130 seconds
Time After: 0.00175 seconds
Time Before: 0.00182 seconds
Time After: 0.00230 seconds
Time Before: 0.00253 seconds
Time After: 0.00265 seconds
Time Before: 0.00332 seconds
Time After: 0.00576 seconds
Time Taken: 0.00244 seconds
Time Before: 0.00270 seconds
Time After: 0.00955 seconds
Time Taken: 0.00685 seconds
Time Before: 0.01177 seconds
Time After: 0.01209 seconds
Time Before: 0.01490 seconds
Time After: 0.01715 seconds
Time Taken: 0.00225 seconds
Time Before: 0.01107 seconds
Time After: 0.01732 seconds
Time Taken: 0.00625 seconds
Time Before: 0.02212 seconds
Time After: 0.02223 seconds
Time Before: 0.02401 seconds
Time After: 0.02521 seconds
Time Before: 0.02812 seconds
Time After: 0.02826 seconds
Time Before: 0.03108 seconds
Time After: 0.03248 seconds
UPDATE session SET lastactivity = 1789145495, location = '/forums/private.php?do=newpm&explain=1&u=74125', badlocation = 1 WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.04776 seconds
Time After: 0.04809 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
