Time Before: 0.00638 seconds
Time After: 0.00891 seconds
Time Taken: 0.00253 seconds
Time Before: 0.00899 seconds
Time After: 0.00945 seconds
Time Before: 0.00973 seconds
Time After: 0.00987 seconds
Time Before: 0.01077 seconds
Time After: 0.01330 seconds
Time Before: 0.00996 seconds
Time After: 0.01836 seconds
Time Taken: 0.00840 seconds
Time Before: 0.02318 seconds
Time After: 0.02364 seconds
Time Before: 0.02630 seconds
Time After: 0.02752 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.02243 seconds
Time After: 0.02780 seconds
Time Taken: 0.00536 seconds
Memory After: 2,261.719 KB
Time Before: 0.03698 seconds
Time After: 0.03711 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.04577 seconds
Time After: 0.04703 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
Time Before: 0.05280 seconds
Time After: 0.05297 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.05541 seconds
Time After: 0.05697 seconds
Time Taken: 0.00156 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=74128' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.07480 seconds
Time After: 0.07503 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
