Time Before: 0.02377 seconds
Time After: 0.03128 seconds
Time Taken: 0.00752 seconds
Time Before: 0.03140 seconds
Time After: 0.03186 seconds
Time Before: 0.03211 seconds
Time After: 0.03227 seconds
Time Before: 0.03305 seconds
Time After: 0.03662 seconds
Time Taken: 0.00357 seconds
Time Before: 0.03233 seconds
Time After: 0.04206 seconds
Time Taken: 0.00973 seconds
Time Before: 0.04996 seconds
Time After: 0.05037 seconds
Time Before: 0.05339 seconds
Time After: 0.05463 seconds
Time Before: 0.04918 seconds
Time After: 0.05494 seconds
Time Taken: 0.00576 seconds
Time Before: 0.09675 seconds
Time After: 0.09691 seconds
Time Before: 0.11933 seconds
Time After: 0.12058 seconds
Time Before: 0.13187 seconds
Time After: 0.13207 seconds
Time Before: 0.13427 seconds
Time After: 0.13571 seconds
UPDATE session SET lastactivity = 1789111446, location = '/forums/private.php?do=newpm&explain=1&u=74134' WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.15482 seconds
Time After: 0.15534 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
