Time Before: 0.00221 seconds
Time After: 0.00288 seconds
Time Taken: 0.00067 seconds
Time Before: 0.00300 seconds
Time After: 0.00342 seconds
Time Before: 0.00364 seconds
Time After: 0.00376 seconds
Time Before: 0.00462 seconds
Time After: 0.00685 seconds
Time Taken: 0.00223 seconds
Time Before: 0.00384 seconds
Time After: 0.01263 seconds
Time Taken: 0.00879 seconds
Time Before: 0.01507 seconds
Time After: 0.01550 seconds
Time Before: 0.01837 seconds
Time After: 0.02012 seconds
Time Taken: 0.00175 seconds
Time Before: 0.01428 seconds
Time After: 0.02034 seconds
Time Taken: 0.00606 seconds
Time Before: 0.02561 seconds
Time After: 0.02583 seconds
Time Before: 0.02784 seconds
Time After: 0.02903 seconds
End call of global.php: 0.030797004699707
Time Before: 0.03219 seconds
Time After: 0.03232 seconds
Time Before: 0.03448 seconds
Time After: 0.03590 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=74244'
Time Before: 0.05028 seconds
Time After: 0.05061 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
Page generated in 0.049378156661987 seconds with 9 queries, spending 0.0082454681396484 doing MySQL queries and 0.041132688522339 doing PHP things.
