Time Before: 0.00519 seconds
Time After: 0.00771 seconds
Time Taken: 0.00252 seconds
Time Before: 0.00784 seconds
Time After: 0.00829 seconds
Time Before: 0.00854 seconds
Time After: 0.00870 seconds
Time Before: 0.00947 seconds
Time After: 0.01199 seconds
Time Before: 0.00877 seconds
Time After: 0.01623 seconds
Time Taken: 0.00746 seconds
Time Before: 0.01975 seconds
Time After: 0.02008 seconds
Time Before: 0.02246 seconds
Time After: 0.02370 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.01911 seconds
Time After: 0.02402 seconds
Time Taken: 0.00491 seconds
Memory After: 2,261.719 KB
Time Before: 0.03465 seconds
Time After: 0.03479 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.04085 seconds
Time After: 0.04204 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.04376482963562
Time Before: 0.04544 seconds
Time After: 0.04560 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.04765 seconds
Time After: 0.04918 seconds
Time Taken: 0.00153 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=74375'
Time Before: 0.06297 seconds
Time After: 0.06373 seconds
Time Taken: 0.00076 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
Page generated in 0.061688899993896 seconds with 9 queries, spending 0.0084879398345947 doing MySQL queries and 0.053200960159302 doing PHP things.
