Time Before: 0.00949 seconds
Time After: 0.01412 seconds
Time Taken: 0.00463 seconds
Time Before: 0.01420 seconds
Time After: 0.01467 seconds
Time Before: 0.01492 seconds
Time After: 0.01503 seconds
Time Taken: 0.00010 seconds
Time Before: 0.01572 seconds
Time After: 0.01763 seconds
Time Taken: 0.00191 seconds
Time Before: 0.01511 seconds
Time After: 0.02206 seconds
Time Taken: 0.00696 seconds
Time Before: 0.02843 seconds
Time After: 0.02877 seconds
Time Before: 0.03061 seconds
Time After: 0.03193 seconds
Time Taken: 0.00131 seconds
Time Before: 0.02754 seconds
Time After: 0.03217 seconds
Time Before: 0.04607 seconds
Time After: 0.04647 seconds
Time Before: 0.05861 seconds
Time After: 0.05988 seconds
End call of global.php: 0.062664985656738
Time Before: 0.06672 seconds
Time After: 0.06688 seconds
Time Before: 0.06914 seconds
Time After: 0.07056 seconds
SET lastactivity = 1788992155, location = '/forums/private.php?do=newpm&explain=1&u=74459'
Time Before: 0.08785 seconds
Time After: 0.08850 seconds
Time Taken: 0.00065 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.086545944213867 seconds with 9 queries, spending 0.0080533027648926 doing MySQL queries and 0.078492641448975 doing PHP things.
