Time Before: 0.00438 seconds
Time After: 0.00709 seconds
Time Taken: 0.00271 seconds
Time Before: 0.00720 seconds
Time After: 0.00767 seconds
Time Before: 0.00792 seconds
Time After: 0.00807 seconds
Time Before: 0.00904 seconds
Time After: 0.01229 seconds
Time Taken: 0.00325 seconds
Time Before: 0.00815 seconds
Time After: 0.01573 seconds
Time Taken: 0.00758 seconds
Time Before: 0.01898 seconds
Time After: 0.01932 seconds
Time Before: 0.02167 seconds
Time After: 0.02290 seconds
Time Before: 0.01841 seconds
Time After: 0.02307 seconds
Time Taken: 0.00467 seconds
Time Before: 0.02980 seconds
Time After: 0.02995 seconds
REPLACE INTO datastore
	(title, data, unserialize)
VALUES
	('loadcache', 'a:2:{s:7:\"loadavg\";s:6:\"25.61,\";s:9:\"lastcheck\";i:1785321360;}', 1)
Time Before: 0.03560 seconds
Time After: 0.03608 seconds
Memory Before: 3,439.641 KB
Memory After: 3,439.891 KB
Memory Used: 0.250 KB
Time Before: 0.03971 seconds
Time After: 0.04100 seconds
Memory Before: 3,526.445 KB
Memory After: 3,527.039 KB
End call of global.php: 0.044456005096436
Time Before: 0.04642 seconds
Time After: 0.04657 seconds
Memory Before: 4,164.313 KB
Memory After: 4,164.742 KB
Time Before: 0.04963 seconds
Time After: 0.05116 seconds
Time Taken: 0.00153 seconds
Memory Before: 4,446.055 KB
Memory After: 4,447.742 KB
SET lastactivity = 1785321360, location = '/forums/private.php?do=newpm&explain=1&u=74514'
Time Before: 0.06925 seconds
Time After: 0.07012 seconds
Time Taken: 0.00087 seconds
Memory Before: 4,919.750 KB
Memory After: 4,919.977 KB
Page generated in 0.067963838577271 seconds with 10 queries, spending 0.0098893642425537 doing MySQL queries and 0.058074474334717 doing PHP things.
