Time Before: 0.01998 seconds
Time After: 0.02483 seconds
Time Taken: 0.00485 seconds
Time Before: 0.02491 seconds
Time After: 0.02535 seconds
Time Before: 0.02730 seconds
Time After: 0.02746 seconds
Time Before: 0.02835 seconds
Time After: 0.03116 seconds
Time Taken: 0.00281 seconds
Time Before: 0.02754 seconds
Time After: 0.03673 seconds
Time Taken: 0.00919 seconds
Time Before: 0.04390 seconds
Time After: 0.04439 seconds
Time Before: 0.04684 seconds
Time After: 0.04807 seconds
Time Before: 0.04320 seconds
Time After: 0.04828 seconds
Time Taken: 0.00508 seconds
Time Before: 0.07495 seconds
Time After: 0.07515 seconds
Time Before: 0.08732 seconds
Time After: 0.08864 seconds
Time Taken: 0.00131 seconds
Time Before: 0.09706 seconds
Time After: 0.09725 seconds
Time Before: 0.09990 seconds
Time After: 0.10148 seconds
Time Taken: 0.00158 seconds
UPDATE session SET lastactivity = 1769064520, location = '/forums/private.php?do=newpm&explain=1&u=74534' WHERE sessionhash = 'cb23636bbd36247f3b1133fdf383bca3'
Time Before: 0.12252 seconds
Time After: 0.12281 seconds
Memory Before: 4,911.945 KB
Memory After: 4,912.172 KB
