Time Before: 0.00217 seconds
Time After: 0.00272 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00283 seconds
Time After: 0.00419 seconds
Time Taken: 0.00136 seconds
Time Before: 0.00444 seconds
Time After: 0.00456 seconds
Time Before: 0.00522 seconds
Time After: 0.00747 seconds
Time Taken: 0.00224 seconds
Time Before: 0.00461 seconds
Time After: 0.01088 seconds
Time Taken: 0.00627 seconds
Time Before: 0.01303 seconds
Time After: 0.01325 seconds
Time Before: 0.01686 seconds
Time After: 0.01906 seconds
Time Taken: 0.00219 seconds
Time Before: 0.01228 seconds
Time After: 0.01924 seconds
Time Taken: 0.00696 seconds
Time Before: 0.02418 seconds
Time After: 0.02432 seconds
Time Before: 0.02618 seconds
Time After: 0.02747 seconds
End call of global.php: 0.029099941253662
Time Before: 0.03077 seconds
Time After: 0.03108 seconds
Time Before: 0.03434 seconds
Time After: 0.03584 seconds
Time Taken: 0.00150 seconds
SET lastactivity = 1776553730, location = '/forums/private.php?do=newpm&explain=1&u=74542', badlocation = 1
Time Before: 0.04986 seconds
Time After: 0.05016 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
Page generated in 0.048923015594482 seconds with 9 queries, spending 0.0096871852874756 doing MySQL queries and 0.039235830307007 doing PHP things.
