Time Before: 0.00152 seconds
Time After: 0.00198 seconds
Time Before: 0.00205 seconds
Time After: 0.00258 seconds
Time Before: 0.00279 seconds
Time After: 0.00300 seconds
Time Before: 0.00378 seconds
Time After: 0.00660 seconds
Time Taken: 0.00282 seconds
Time Before: 0.00309 seconds
Time After: 0.01099 seconds
Time Taken: 0.00790 seconds
Time Before: 0.01338 seconds
Time After: 0.01384 seconds
Time Before: 0.01642 seconds
Time After: 0.01773 seconds
Time Taken: 0.00131 seconds
Time Before: 0.01266 seconds
Time After: 0.01790 seconds
Time Taken: 0.00524 seconds
Time Before: 0.02330 seconds
Time After: 0.02351 seconds
Time Before: 0.02571 seconds
Time After: 0.02703 seconds
Time Taken: 0.00132 seconds
Time Before: 0.03083 seconds
Time After: 0.03103 seconds
Time Before: 0.03304 seconds
Time After: 0.03452 seconds
UPDATE session SET lastactivity = 1782880011, location = '/forums/private.php?do=newpm&explain=1&u=74554', badlocation = 1 WHERE sessionhash = '90b3c67278b177629fe550ebf4d83bbe'
Time Before: 0.04806 seconds
Time After: 0.04837 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
