Time Before: 0.01490 seconds
Time After: 0.02269 seconds
Time Taken: 0.00778 seconds
Time Before: 0.02278 seconds
Time After: 0.02322 seconds
Time Before: 0.02347 seconds
Time After: 0.02365 seconds
Time Before: 0.02445 seconds
Time After: 0.02636 seconds
Time Taken: 0.00192 seconds
Time Before: 0.02373 seconds
Time After: 0.03125 seconds
Time Taken: 0.00752 seconds
Time Before: 0.03802 seconds
Time After: 0.03839 seconds
Time Before: 0.03985 seconds
Time After: 0.04107 seconds
Time Before: 0.03719 seconds
Time After: 0.04133 seconds
Time Taken: 0.00414 seconds
Time Before: 0.06953 seconds
Time After: 0.06970 seconds
Time Before: 0.08437 seconds
Time After: 0.08603 seconds
Time Taken: 0.00166 seconds
End call of global.php: 0.089075803756714
Time Before: 0.09632 seconds
Time After: 0.09650 seconds
Time Before: 0.09915 seconds
Time After: 0.10104 seconds
Time Taken: 0.00189 seconds
SET lastactivity = 1789107634, location = '/forums/private.php?do=newpm&explain=1&u=74562', badlocation = 1
Time Before: 0.11968 seconds
Time After: 0.12006 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.11861085891724 seconds with 9 queries, spending 0.0084078311920166 doing MySQL queries and 0.11020302772522 doing PHP things.
