Time Before: 0.01555 seconds
Time After: 0.02331 seconds
Time Taken: 0.00777 seconds
Time Before: 0.02340 seconds
Time After: 0.02390 seconds
Time Before: 0.02418 seconds
Time After: 0.02433 seconds
Time Before: 0.02508 seconds
Time After: 0.02735 seconds
Time Taken: 0.00227 seconds
Time Before: 0.02440 seconds
Time After: 0.03175 seconds
Time Taken: 0.00735 seconds
Time Before: 0.03846 seconds
Time After: 0.03885 seconds
Time Before: 0.04135 seconds
Time After: 0.04259 seconds
Time Before: 0.03776 seconds
Time After: 0.04281 seconds
Time Taken: 0.00504 seconds
Time Before: 0.07089 seconds
Time After: 0.07102 seconds
Time Before: 0.08861 seconds
Time After: 0.08985 seconds
Time Before: 0.09734 seconds
Time After: 0.09755 seconds
Time Before: 0.10010 seconds
Time After: 0.10160 seconds
Time Taken: 0.00150 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=74702' WHERE sessionhash = '90b3c67278b177629fe550ebf4d83bbe'
Time Before: 0.11947 seconds
Time After: 0.11978 seconds
Memory Before: 4,288.555 KB
Memory After: 4,288.797 KB
