Time Before: 0.01551 seconds
Time After: 0.02315 seconds
Time Taken: 0.00764 seconds
Time Before: 0.02325 seconds
Time After: 0.02362 seconds
Time Before: 0.02385 seconds
Time After: 0.02399 seconds
Time Before: 0.02465 seconds
Time After: 0.02704 seconds
Time Taken: 0.00239 seconds
Time Before: 0.02404 seconds
Time After: 0.03128 seconds
Time Taken: 0.00724 seconds
Time Before: 0.04122 seconds
Time After: 0.04149 seconds
Time Before: 0.04326 seconds
Time After: 0.04449 seconds
Time Before: 0.04059 seconds
Time After: 0.04479 seconds
Time Taken: 0.00420 seconds
Time Before: 0.07723 seconds
Time After: 0.07737 seconds
Time Before: 0.92272 seconds
Time After: 0.92445 seconds
Time Taken: 0.00173 seconds
End call of global.php: 0.92659997940063
Time Before: 0.93278 seconds
Time After: 0.93296 seconds
Time Before: 0.93628 seconds
Time After: 0.93785 seconds
Time Taken: 0.00157 seconds
SET lastactivity = 1776998837, location = '/forums/private.php?do=newpm&explain=1&u=74861', badlocation = 1
WHERE sessionhash = 'df28b2ca2ba03bfc49481a2edca83948'
Time Before: 0.95782 seconds
Time After: 0.95815 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
Page generated in 0.95679998397827 seconds with 9 queries, spending 0.008338451385498 doing MySQL queries and 0.94846153259277 doing PHP things.
