Time Before: 0.02175 seconds
Time After: 0.03032 seconds
Time Taken: 0.00857 seconds
Time Before: 0.03043 seconds
Time After: 0.03094 seconds
Time Before: 0.03117 seconds
Time After: 0.03135 seconds
Time Before: 0.03224 seconds
Time After: 0.03554 seconds
Time Taken: 0.00330 seconds
Time Before: 0.03141 seconds
Time After: 0.04041 seconds
Time Taken: 0.00900 seconds
Time Before: 0.04935 seconds
Time After: 0.04977 seconds
Time Before: 0.05299 seconds
Time After: 0.05422 seconds
Time Before: 0.04861 seconds
Time After: 0.05441 seconds
Time Taken: 0.00580 seconds
Time Before: 0.08320 seconds
Time After: 0.08334 seconds
Time Before: 0.10501 seconds
Time After: 0.10626 seconds
Time Before: 0.11584 seconds
Time After: 0.11598 seconds
Time Before: 0.11866 seconds
Time After: 0.12013 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=75317' WHERE sessionhash = '84d505ff74940a4d05f0ae95a61eba7a'
Time Before: 0.14380 seconds
Time After: 0.14406 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
