Time Before: 0.01482 seconds
Time After: 0.01806 seconds
Time Taken: 0.00324 seconds
Time Before: 0.01816 seconds
Time After: 0.01859 seconds
Time Before: 0.01882 seconds
Time After: 0.01896 seconds
Time Before: 0.01984 seconds
Time After: 0.02269 seconds
Time Taken: 0.00285 seconds
Time Before: 0.01906 seconds
Time After: 0.02702 seconds
Time Taken: 0.00796 seconds
Time Before: 0.03323 seconds
Time After: 0.03366 seconds
Time Before: 0.03631 seconds
Time After: 0.03987 seconds
Time Taken: 0.00356 seconds
Time Before: 0.03259 seconds
Time After: 0.04004 seconds
Time Taken: 0.00746 seconds
Time Before: 0.06654 seconds
Time After: 0.06670 seconds
Time Before: 0.07652 seconds
Time After: 0.07782 seconds
End call of global.php: 0.080150842666626
Time Before: 0.08616 seconds
Time After: 0.08632 seconds
Time Before: 0.08871 seconds
Time After: 0.09052 seconds
Time Taken: 0.00181 seconds
SET lastactivity = 1784989092, location = '/forums/private.php?do=newpm&explain=1&u=75553', badlocation = 1
WHERE sessionhash = 'e0f24550e916c0d25518ad14fd8d75f0'
Time Before: 0.10560 seconds
Time After: 0.10594 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
Page generated in 0.10468196868896 seconds with 9 queries, spending 0.011169910430908 doing MySQL queries and 0.093512058258057 doing PHP things.
