Time Before: 0.02054 seconds
Time After: 0.02473 seconds
Time Taken: 0.00419 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.02482 seconds
Time After: 0.02521 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.02546 seconds
Time After: 0.02560 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.02664 seconds
Time After: 0.02886 seconds
Time Taken: 0.00222 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.02566 seconds
Time After: 0.03317 seconds
Time Taken: 0.00751 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.03966 seconds
Time After: 0.03994 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.04318 seconds
Time After: 0.04436 seconds
Time Taken: 0.00117 seconds
Memory Before: 2,908.203 KB
Memory After: 2,908.063 KB
Time Before: 0.03888 seconds
Time After: 0.04458 seconds
Time Taken: 0.00569 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.133 KB
Memory Used: 132.531 KB
Time Before: 0.09526 seconds
Time After: 0.09544 seconds
Memory Before: 3,655.734 KB
Memory After: 3,656.250 KB
Time Before: 0.16240 seconds
Time After: 0.16368 seconds
Memory Before: 4,133.250 KB
Memory After: 4,133.844 KB
Time Before: 0.19332 seconds
Time After: 0.19382 seconds
Memory Before: 5,197.492 KB
Memory After: 5,325.836 KB
Time Before: 0.19961 seconds
Time After: 0.20104 seconds
Memory Before: 5,481.172 KB
Memory After: 5,610.773 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=75625', badlocation = 1 WHERE sessionhash = '8385044bee7d6de684cfeaf823df6777'
Time Before: 0.23026 seconds
Time After: 0.23057 seconds
Memory Before: 5,998.492 KB
Memory After: 5,998.711 KB
