Time Before: 0.00406 seconds
Time After: 0.00537 seconds
Time Taken: 0.00131 seconds
Time Before: 0.00547 seconds
Time After: 0.00588 seconds
Time Before: 0.00617 seconds
Time After: 0.00631 seconds
Time Before: 0.00723 seconds
Time After: 0.00997 seconds
Time Taken: 0.00274 seconds
Time Before: 0.00638 seconds
Time After: 0.01488 seconds
Time Taken: 0.00850 seconds
Time Before: 0.01944 seconds
Time After: 0.01993 seconds
Time Before: 0.02344 seconds
Time After: 0.02475 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.01865 seconds
Time After: 0.02503 seconds
Time Taken: 0.00638 seconds
Memory After: 2,261.836 KB
Time Before: 0.03769 seconds
Time After: 0.03805 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.04355 seconds
Time After: 0.04538 seconds
Time Taken: 0.00183 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
Time Before: 0.05162 seconds
Time After: 0.05184 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.05544 seconds
Time After: 0.05695 seconds
Time Taken: 0.00152 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
UPDATE session SET lastactivity = 1788873084, location = '/forums/private.php?do=newpm&explain=1&u=75642' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.07629 seconds
Time After: 0.07692 seconds
Time Taken: 0.00063 seconds
Memory Before: 4,287.578 KB
Memory After: 4,287.805 KB
