Time Before: 0.01622 seconds
Time After: 0.02291 seconds
Time Taken: 0.00669 seconds
Time Before: 0.02299 seconds
Time After: 0.02342 seconds
Time Before: 0.02374 seconds
Time After: 0.02386 seconds
Time Before: 0.02467 seconds
Time After: 0.02693 seconds
Time Taken: 0.00226 seconds
Time Before: 0.02392 seconds
Time After: 0.03123 seconds
Time Taken: 0.00731 seconds
Time Before: 0.03770 seconds
Time After: 0.03813 seconds
Time Before: 0.04130 seconds
Time After: 0.04254 seconds
Time Before: 0.03687 seconds
Time After: 0.04278 seconds
Time Taken: 0.00592 seconds
Time Before: 0.06306 seconds
Time After: 0.06320 seconds
Time Before: 0.07497 seconds
Time After: 0.07622 seconds
End call of global.php: 0.078550100326538
Time Before: 0.08521 seconds
Time After: 0.08540 seconds
Time Before: 0.08819 seconds
Time After: 0.09022 seconds
Time Taken: 0.00202 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=75660', badlocation = 1
Time Before: 0.11104 seconds
Time After: 0.11140 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
Page generated in 0.11004018783569 seconds with 9 queries, spending 0.0084302425384521 doing MySQL queries and 0.10160994529724 doing PHP things.
