Time Before: 0.00314 seconds
Time After: 0.00398 seconds
Time Taken: 0.00083 seconds
Time Before: 0.00405 seconds
Time After: 0.00444 seconds
Time Before: 0.00464 seconds
Time After: 0.00476 seconds
Time Before: 0.00546 seconds
Time After: 0.00796 seconds
Time Taken: 0.00250 seconds
Time Before: 0.00481 seconds
Time After: 0.01148 seconds
Time Taken: 0.00668 seconds
Time Before: 0.01391 seconds
Time After: 0.01431 seconds
Time Before: 0.01733 seconds
Time After: 0.01850 seconds
Time Taken: 0.00117 seconds
Time Before: 0.01327 seconds
Time After: 0.01867 seconds
Time Taken: 0.00539 seconds
Time Before: 0.02670 seconds
Time After: 0.02682 seconds
Time Before: 0.03024 seconds
Time After: 0.03151 seconds
End call of global.php: 0.033180952072144
Time Before: 0.03523 seconds
Time After: 0.03537 seconds
Time Before: 0.03744 seconds
Time After: 0.03888 seconds
SET lastactivity = 1785327321, location = '/forums/private.php?do=newpm&explain=1&u=75878'
Time Before: 0.05254 seconds
Time After: 0.05290 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.051567077636719 seconds with 9 queries, spending 0.0079190731048584 doing MySQL queries and 0.04364800453186 doing PHP things.
