Time Before: 0.00555 seconds
Time After: 0.00673 seconds
Time Taken: 0.00118 seconds
Time Before: 0.00680 seconds
Time After: 0.00720 seconds
Time Before: 0.00741 seconds
Time After: 0.00756 seconds
Time Before: 0.00827 seconds
Time After: 0.01098 seconds
Time Taken: 0.00271 seconds
Time Before: 0.00761 seconds
Time After: 0.01512 seconds
Time Taken: 0.00751 seconds
Time Before: 0.01867 seconds
Time After: 0.01903 seconds
Time Before: 0.02147 seconds
Time After: 0.02270 seconds
Time Before: 0.01803 seconds
Time After: 0.02293 seconds
Time Taken: 0.00490 seconds
Time Before: 0.03761 seconds
Time After: 0.03777 seconds
Time Before: 0.04487 seconds
Time After: 0.04635 seconds
Time Before: 0.05221 seconds
Time After: 0.05237 seconds
Time Before: 0.05533 seconds
Time After: 0.05681 seconds
UPDATE session SET lastactivity = 1785314183, location = '/forums/private.php?do=newpm&explain=1&u=75991' WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.07436 seconds
Time After: 0.07464 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
