Time Before: 0.01254 seconds
Time After: 0.02103 seconds
Time Taken: 0.00849 seconds
Time Before: 0.02113 seconds
Time After: 0.02164 seconds
Time Before: 0.02188 seconds
Time After: 0.02201 seconds
Time Before: 0.02296 seconds
Time After: 0.02561 seconds
Time Taken: 0.00265 seconds
Time Before: 0.02209 seconds
Time After: 0.02988 seconds
Time Taken: 0.00779 seconds
Time Before: 0.03928 seconds
Time After: 0.03952 seconds
Time Before: 0.04288 seconds
Time After: 0.04429 seconds
Time Before: 0.03850 seconds
Time After: 0.04456 seconds
Time Taken: 0.00606 seconds
Time Before: 0.06411 seconds
Time After: 0.06424 seconds
Time Before: 0.08093 seconds
Time After: 0.08216 seconds
End call of global.php: 0.084362030029297
Time Before: 0.08898 seconds
Time After: 0.08928 seconds
Time Before: 0.09223 seconds
Time After: 0.09368 seconds
SET lastactivity = 1776819517, location = '/forums/private.php?do=newpm&explain=1&u=76031'
Time Before: 0.11681 seconds
Time After: 0.11721 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.11530613899231 seconds with 9 queries, spending 0.0084297657012939 doing MySQL queries and 0.10687637329102 doing PHP things.
