Time Before: 0.00152 seconds
Time After: 0.00218 seconds
Time Taken: 0.00066 seconds
Time Before: 0.00228 seconds
Time After: 0.00288 seconds
Time Taken: 0.00060 seconds
Time Before: 0.00312 seconds
Time After: 0.00329 seconds
Time Before: 0.00398 seconds
Time After: 0.00690 seconds
Time Taken: 0.00292 seconds
Time Before: 0.00333 seconds
Time After: 0.01030 seconds
Time Taken: 0.00697 seconds
Time Before: 0.01210 seconds
Time After: 0.01239 seconds
Time Before: 0.01485 seconds
Time After: 0.01623 seconds
Time Taken: 0.00137 seconds
Time Before: 0.01147 seconds
Time After: 0.01641 seconds
Time Taken: 0.00494 seconds
Time Before: 0.02125 seconds
Time After: 0.02141 seconds
Time Before: 0.02409 seconds
Time After: 0.02530 seconds
Time Before: 0.02819 seconds
Time After: 0.02834 seconds
Time Before: 0.03036 seconds
Time After: 0.03178 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=76162', badlocation = 1 WHERE sessionhash = '90b3c67278b177629fe550ebf4d83bbe'
Time Before: 0.04446 seconds
Time After: 0.04469 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
