Time Before: 0.00197 seconds
Time After: 0.00249 seconds
Time Before: 0.00256 seconds
Time After: 0.00296 seconds
Time Before: 0.00317 seconds
Time After: 0.00331 seconds
Time Before: 0.00423 seconds
Time After: 0.00765 seconds
Time Taken: 0.00342 seconds
Time Before: 0.00338 seconds
Time After: 0.01287 seconds
Time Taken: 0.00949 seconds
Time Before: 0.01478 seconds
Time After: 0.01516 seconds
Time Before: 0.01690 seconds
Time After: 0.01837 seconds
Time Before: 0.01407 seconds
Time After: 0.01858 seconds
Time Taken: 0.00451 seconds
Time Before: 0.02647 seconds
Time After: 0.02724 seconds
Time Taken: 0.00077 seconds
Time Before: 0.02909 seconds
Time After: 0.03036 seconds
Time Before: 0.03321 seconds
Time After: 0.03337 seconds
Time Before: 0.03540 seconds
Time After: 0.03686 seconds
UPDATE session SET lastactivity = 1785298136, location = '/forums/private.php?do=newpm&explain=1&u=76187' WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.04955 seconds
Time After: 0.04985 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
