Time Before: 0.00578 seconds
Time After: 0.00829 seconds
Time Taken: 0.00252 seconds
Memory Before: 533.906 KB
Memory After: 559.023 KB
Time Before: 0.00838 seconds
Time After: 0.00879 seconds
Memory Before: 558.961 KB
Memory After: 559.969 KB
Time Before: 0.00928 seconds
Time After: 0.00942 seconds
Memory Before: 560.523 KB
Memory After: 561.047 KB
Time Before: 0.01031 seconds
Time After: 0.01294 seconds
Time Taken: 0.00263 seconds
Memory Before: 563.648 KB
Memory After: 564.570 KB
Time Before: 0.00950 seconds
Time After: 0.01698 seconds
Time Taken: 0.00749 seconds
Memory Before: 560.297 KB
Memory After: 1,641.297 KB
Memory Used: 1,081.000 KB
Time Before: 0.02092 seconds
Time After: 0.02128 seconds
Memory Before: 2,136.141 KB
Memory After: 2,136.758 KB
Time Before: 0.02398 seconds
Time After: 0.02516 seconds
Time Taken: 0.00118 seconds
Memory Before: 2,148.320 KB
Memory After: 2,148.180 KB
Time Before: 0.02025 seconds
Time After: 0.02533 seconds
Time Taken: 0.00508 seconds
Memory Before: 2,128.320 KB
Memory After: 2,261.203 KB
Time Before: 0.04363 seconds
Time After: 0.04378 seconds
Memory Before: 2,814.781 KB
Memory After: 2,815.297 KB
Time Before: 0.05123 seconds
Time After: 0.05276 seconds
Time Taken: 0.00153 seconds
Memory Before: 2,903.117 KB
Memory After: 2,903.711 KB
End call of global.php: 0.054780960083008
Time Before: 0.05835 seconds
Time After: 0.05849 seconds
Memory Before: 3,539.836 KB
Memory After: 3,540.266 KB
Time Before: 0.06073 seconds
Time After: 0.06217 seconds
Memory Before: 3,821.367 KB
Memory After: 3,823.055 KB
SET lastactivity = 1789066076, location = '/forums/private.php?do=newpm&explain=1&u=76277'
Time Before: 0.07815 seconds
Time After: 0.07844 seconds
Memory Before: 4,295.203 KB
Memory After: 4,295.430 KB
Page generated in 0.077101945877075 seconds with 9 queries, spending 0.0082724094390869 doing MySQL queries and 0.068829536437988 doing PHP things.
