Time Before: 0.00160 seconds
Time After: 0.00205 seconds
Time Before: 0.00212 seconds
Time After: 0.00251 seconds
Time Before: 0.00273 seconds
Time After: 0.00289 seconds
Time Before: 0.00353 seconds
Time After: 0.00578 seconds
Time Taken: 0.00225 seconds
Time Before: 0.00293 seconds
Time After: 0.00984 seconds
Time Taken: 0.00691 seconds
Time Before: 0.01164 seconds
Time After: 0.01208 seconds
Time Before: 0.01352 seconds
Time After: 0.01475 seconds
Time Before: 0.01106 seconds
Time After: 0.01492 seconds
Time Taken: 0.00386 seconds
Time Before: 0.02007 seconds
Time After: 0.02025 seconds
Time Before: 0.02270 seconds
Time After: 0.02391 seconds
End call of global.php: 0.025882959365845
Time Before: 0.02759 seconds
Time After: 0.02773 seconds
Time Before: 0.03062 seconds
Time After: 0.03210 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=76292'
Time Before: 0.05197 seconds
Time After: 0.05235 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.050858020782471 seconds with 9 queries, spending 0.0078604221343994 doing MySQL queries and 0.042997598648071 doing PHP things.
