Time Before: 0.02151 seconds
Time After: 0.03136 seconds
Time Taken: 0.00985 seconds
Memory Before: 534.445 KB
Memory After: 559.563 KB
Time Before: 0.03152 seconds
Time After: 0.03272 seconds
Memory Before: 559.500 KB
Memory After: 560.508 KB
Time Before: 0.03306 seconds
Time After: 0.03319 seconds
Memory Before: 561.063 KB
Memory After: 561.586 KB
Time Before: 0.03403 seconds
Time After: 0.03632 seconds
Time Taken: 0.00229 seconds
Memory Before: 564.188 KB
Memory After: 565.109 KB
Time Before: 0.03327 seconds
Time After: 0.04175 seconds
Time Taken: 0.00848 seconds
Memory Before: 560.836 KB
Memory Used: 1,080.992 KB
Time Before: 0.04940 seconds
Time After: 0.04971 seconds
Time Before: 0.05162 seconds
Time After: 0.05288 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.04866 seconds
Time After: 0.05330 seconds
Time Taken: 0.00464 seconds
Memory After: 2,261.750 KB
Memory Used: 132.797 KB
Time Before: 0.08154 seconds
Time After: 0.08172 seconds
Memory Before: 2,815.313 KB
Memory After: 2,815.828 KB
Time Before: 0.10258 seconds
Time After: 0.10385 seconds
Memory Before: 2,903.508 KB
Memory After: 2,904.102 KB
Time Before: 0.11247 seconds
Time After: 0.11264 seconds
Memory Before: 3,540.320 KB
Memory After: 3,540.750 KB
Time Before: 0.11502 seconds
Time After: 0.11645 seconds
Memory Before: 3,821.875 KB
Memory After: 3,823.563 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=76511' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.13765 seconds
Time After: 0.13796 seconds
Memory Before: 4,287.281 KB
Memory After: 4,287.523 KB
