Time Before: 0.01941 seconds
Time After: 0.02904 seconds
Time Taken: 0.00962 seconds
Time Before: 0.02912 seconds
Time After: 0.02968 seconds
Time Taken: 0.00056 seconds
Time Before: 0.02991 seconds
Time After: 0.03009 seconds
Time Before: 0.03088 seconds
Time After: 0.03414 seconds
Time Taken: 0.00326 seconds
Time Before: 0.03014 seconds
Time After: 0.03920 seconds
Time Taken: 0.00906 seconds
Time Before: 0.05348 seconds
Time After: 0.05387 seconds
Time Before: 0.05636 seconds
Time After: 0.05760 seconds
Time Before: 0.05280 seconds
Time After: 0.05780 seconds
Time Taken: 0.00500 seconds
Time Before: 0.08469 seconds
Time After: 0.08486 seconds
REPLACE INTO datastore
	(title, data, unserialize)
VALUES
	('loadcache', 'a:2:{s:7:\"loadavg\";s:5:\"8.08,\";s:9:\"lastcheck\";i:1788967303;}', 1)
Time Before: 0.10804 seconds
Time After: 0.10860 seconds
Memory Before: 3,439.641 KB
Memory After: 3,439.891 KB
Memory Used: 0.250 KB
Time Before: 0.12560 seconds
Time After: 0.12692 seconds
Time Taken: 0.00132 seconds
Memory Before: 3,526.430 KB
Memory After: 3,527.023 KB
End call of global.php: 0.13011693954468
Time Before: 0.13794 seconds
Time After: 0.13813 seconds
Memory Before: 4,164.305 KB
Memory After: 4,164.734 KB
Time Before: 0.14096 seconds
Time After: 0.14242 seconds
Memory Before: 4,446.094 KB
Memory After: 4,447.781 KB
SET lastactivity = 1788967303, location = '/forums/private.php?do=newpm&explain=1&u=76519', badlocation = 1
Time Before: 0.16020 seconds
Time After: 0.16045 seconds
Memory Before: 4,920.039 KB
Memory After: 4,920.250 KB
Page generated in 0.15919709205627 seconds with 10 queries, spending 0.0095875263214111 doing MySQL queries and 0.14960956573486 doing PHP things.
