Time Before: 0.02911 seconds
Time After: 0.03900 seconds
Time Taken: 0.00989 seconds
Time Before: 0.03912 seconds
Time After: 0.03962 seconds
Time Before: 0.03990 seconds
Time After: 0.04006 seconds
Time Before: 0.04109 seconds
Time After: 0.04324 seconds
Time Taken: 0.00215 seconds
Time Before: 0.04014 seconds
Time After: 0.04777 seconds
Time Taken: 0.00763 seconds
Time Before: 0.06145 seconds
Time After: 0.06188 seconds
Time Before: 0.06363 seconds
Time After: 0.06495 seconds
Time Taken: 0.00132 seconds
Time Before: 0.06048 seconds
Time After: 0.06521 seconds
Time Taken: 0.00473 seconds
Time Before: 0.10263 seconds
Time After: 0.10278 seconds
Time Before: 0.12662 seconds
Time After: 0.12785 seconds
Time Before: 0.13962 seconds
Time After: 0.13978 seconds
Time Before: 0.14244 seconds
Time After: 0.14394 seconds
Time Taken: 0.00150 seconds
UPDATE session SET lastactivity = 1783034723, location = '/forums/private.php?do=newpm&explain=1&u=76531', badlocation = 1 WHERE sessionhash = 'f9921609250f226198462d57df303337'
Time Before: 0.16360 seconds
Time After: 0.16409 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
