Time Before: 0.03038 seconds
Time After: 0.04048 seconds
Time Taken: 0.01011 seconds
Time Before: 0.04059 seconds
Time After: 0.04102 seconds
Time Before: 0.04134 seconds
Time After: 0.04149 seconds
Time Before: 0.04236 seconds
Time After: 0.04438 seconds
Time Taken: 0.00202 seconds
Time Before: 0.04155 seconds
Time After: 0.04847 seconds
Time Taken: 0.00692 seconds
Time Before: 0.05910 seconds
Time After: 0.05976 seconds
Time Taken: 0.00066 seconds
Time Before: 0.06339 seconds
Time After: 0.06459 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.05794 seconds
Time After: 0.06485 seconds
Memory After: 2,261.719 KB
Time Before: 0.11398 seconds
Time After: 0.11412 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.13012 seconds
Time After: 0.13205 seconds
Time Taken: 0.00193 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.13428401947021
Time Before: 0.14262 seconds
Time After: 0.14279 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.14536 seconds
Time After: 0.14683 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=76591', badlocation = 1
Time Before: 0.16451 seconds
Time After: 0.16479 seconds
Memory Before: 4,287.500 KB
Memory After: 4,287.727 KB
Page generated in 0.16349697113037 seconds with 9 queries, spending 0.0084342956542969 doing MySQL queries and 0.15506267547607 doing PHP things.
