Time Before: 0.00151 seconds
Time After: 0.00203 seconds
Time Before: 0.00210 seconds
Time After: 0.00248 seconds
Time Before: 0.00273 seconds
Time After: 0.00292 seconds
Time Before: 0.00380 seconds
Time After: 0.00651 seconds
Time Taken: 0.00271 seconds
Time Before: 0.00299 seconds
Time After: 0.00990 seconds
Time Taken: 0.00690 seconds
Time Before: 0.01171 seconds
Time After: 0.01211 seconds
Time Before: 0.01523 seconds
Time After: 0.01652 seconds
Time Before: 0.01113 seconds
Time After: 0.01682 seconds
Time Taken: 0.00570 seconds
Time Before: 0.02541 seconds
Time After: 0.02556 seconds
REPLACE INTO datastore
(title, data, unserialize)
VALUES
('loadcache', 'a:2:{s:7:\"loadavg\";s:6:\"22.70,\";s:9:\"lastcheck\";i:1782939901;}', 1)Time Before: 0.03254 seconds
Time After: 0.03317 seconds
Time Taken: 0.00063 seconds
Memory Before: 2,817.273 KB
Memory After: 2,817.523 KB
Memory Used: 0.250 KB
Time Before: 0.03625 seconds
Time After: 0.03749 seconds
Memory Before: 2,904.578 KB
Memory After: 2,905.172 KB
Time Before: 0.04139 seconds
Time After: 0.04154 seconds
Memory Before: 3,541.367 KB
Memory After: 3,541.797 KB
Time Before: 0.04375 seconds
Time After: 0.04519 seconds
Memory Before: 3,823.109 KB
Memory After: 3,824.797 KB
UPDATE session SET lastactivity = 1782939901, location = '/forums/private.php?do=newpm&explain=1&u=7677', badlocation = 1 WHERE sessionhash = '90b3c67278b177629fe550ebf4d83bbe'
Time Before: 0.05793 seconds
Time After: 0.05820 seconds
Memory Before: 4,297.063 KB
Memory After: 4,297.273 KB
