Time Before: 0.01609 seconds
Time After: 0.02370 seconds
Time Taken: 0.00761 seconds
Time Before: 0.02381 seconds
Time After: 0.02507 seconds
Time Before: 0.02532 seconds
Time After: 0.02545 seconds
Time Before: 0.02631 seconds
Time After: 0.02888 seconds
Time Taken: 0.00257 seconds
Time Before: 0.02552 seconds
Time After: 0.03313 seconds
Time Before: 0.04035 seconds
Time After: 0.04078 seconds
Time Before: 0.04369 seconds
Time After: 0.04492 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.03963 seconds
Time After: 0.04514 seconds
Time Taken: 0.00551 seconds
Memory After: 2,261.719 KB
Time Before: 0.06883 seconds
Time After: 0.06896 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.08670 seconds
Time After: 0.08876 seconds
Time Taken: 0.00205 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.091233015060425
Time Before: 0.09681 seconds
Time After: 0.09702 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.09977 seconds
Time After: 0.10209 seconds
Time Taken: 0.00232 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=76896'
Time Before: 0.12253 seconds
Time After: 0.12294 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
Page generated in 0.12148714065552 seconds with 9 queries, spending 0.010740041732788 doing MySQL queries and 0.11074709892273 doing PHP things.
