Time Before: 0.01623 seconds
Time After: 0.02157 seconds
Time Taken: 0.00534 seconds
Time Before: 0.02167 seconds
Time After: 0.02206 seconds
Time Before: 0.02230 seconds
Time After: 0.02241 seconds
Time Before: 0.02318 seconds
Time After: 0.02564 seconds
Time Taken: 0.00246 seconds
Time Before: 0.02248 seconds
Time After: 0.02943 seconds
Time Taken: 0.00695 seconds
Time Before: 0.03904 seconds
Time After: 0.03943 seconds
Time Before: 0.04236 seconds
Time After: 0.04358 seconds
Time Before: 0.03825 seconds
Time After: 0.04381 seconds
Time Taken: 0.00556 seconds
Time Before: 0.08120 seconds
Time After: 0.08132 seconds
Time Before: 0.09871 seconds
Time After: 0.09995 seconds
Time Before: 0.11338 seconds
Time After: 0.11352 seconds
Time Before: 0.11646 seconds
Time After: 0.11793 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=76898' WHERE sessionhash = '7ca6ab718f0d2129a0db1a6bd7e3c55b'
Time Before: 0.13817 seconds
Time After: 0.13845 seconds
Memory Before: 4,911.656 KB
Memory After: 4,911.898 KB
