Time Before: 0.00799 seconds
Time After: 0.01041 seconds
Time Taken: 0.00242 seconds
Time Before: 0.01053 seconds
Time After: 0.01102 seconds
Time Before: 0.01128 seconds
Time After: 0.01140 seconds
Time Before: 0.01218 seconds
Time After: 0.01439 seconds
Time Taken: 0.00222 seconds
Time Before: 0.01147 seconds
Time After: 0.01898 seconds
Time Taken: 0.00751 seconds
Time Before: 0.02324 seconds
Time After: 0.02372 seconds
Time Before: 0.02625 seconds
Time After: 0.02747 seconds
Time Before: 0.02259 seconds
Time After: 0.02769 seconds
Time Taken: 0.00510 seconds
Time Before: 0.04535 seconds
Time After: 0.04551 seconds
Time Before: 0.05268 seconds
Time After: 0.05396 seconds
Time Before: 0.06068 seconds
Time After: 0.06084 seconds
Time Before: 0.06394 seconds
Time After: 0.06538 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=76914', badlocation = 1 WHERE sessionhash = '19bddeacfb649beeea65b05d036d70bd'
Time Before: 0.08309 seconds
Time After: 0.08337 seconds
Memory Before: 4,288.836 KB
Memory After: 4,289.063 KB
