Time Before: 0.00141 seconds
Time After: 0.00195 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00202 seconds
Time After: 0.00256 seconds
Time Before: 0.00282 seconds
Time After: 0.00299 seconds
Time Before: 0.00364 seconds
Time After: 0.00648 seconds
Time Taken: 0.00284 seconds
Time Before: 0.00304 seconds
Time After: 0.01024 seconds
Time Taken: 0.00720 seconds
Time Before: 0.01222 seconds
Time After: 0.01268 seconds
Time Before: 0.01401 seconds
Time After: 0.01549 seconds
Time Before: 0.01159 seconds
Time After: 0.01574 seconds
Time Taken: 0.00415 seconds
Time Before: 0.02122 seconds
Time After: 0.02145 seconds
Time Before: 0.02317 seconds
Time After: 0.02447 seconds
Time Taken: 0.00131 seconds
End call of global.php: 0.026956081390381
Time Before: 0.02809 seconds
Time After: 0.02826 seconds
Time Before: 0.03022 seconds
Time After: 0.03161 seconds
Time Taken: 0.00139 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=76943'
Time Before: 0.04742 seconds
Time After: 0.04777 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.046504020690918 seconds with 9 queries, spending 0.0089406967163086 doing MySQL queries and 0.037563323974609 doing PHP things.
