Time Before: 0.00217 seconds
Time After: 0.00302 seconds
Time Taken: 0.00085 seconds
Time Before: 0.00312 seconds
Time After: 0.00354 seconds
Time Before: 0.00379 seconds
Time After: 0.00391 seconds
Time Before: 0.00460 seconds
Time After: 0.00719 seconds
Time Taken: 0.00259 seconds
Time Before: 0.00400 seconds
Time After: 0.01153 seconds
Time Taken: 0.00753 seconds
Time Before: 0.01345 seconds
Time After: 0.01389 seconds
Time Before: 0.01687 seconds
Time After: 0.01817 seconds
Time Before: 0.01285 seconds
Time After: 0.01843 seconds
Time Taken: 0.00557 seconds
Time Before: 0.02644 seconds
Time After: 0.02656 seconds
Time Before: 0.02978 seconds
Time After: 0.03108 seconds
Time Before: 0.03546 seconds
Time After: 0.03560 seconds
Time Before: 0.03865 seconds
Time After: 0.04019 seconds
Time Taken: 0.00154 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=76948', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.05444 seconds
Time After: 0.05480 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
