Time Before: 0.00201 seconds
Time After: 0.00268 seconds
Time Taken: 0.00067 seconds
Time Before: 0.00278 seconds
Time After: 0.00330 seconds
Time Before: 0.00366 seconds
Time After: 0.00388 seconds
Time Before: 0.00475 seconds
Time After: 0.00822 seconds
Time Taken: 0.00347 seconds
Time Before: 0.00396 seconds
Time After: 0.01170 seconds
Time Taken: 0.00775 seconds
Time Before: 0.01347 seconds
Time After: 0.01384 seconds
Time Before: 0.01614 seconds
Time After: 0.01736 seconds
Time Before: 0.01289 seconds
Time After: 0.01755 seconds
Time Taken: 0.00465 seconds
Time Before: 0.02275 seconds
Time After: 0.02292 seconds
Time Before: 0.02464 seconds
Time After: 0.02586 seconds
Time Before: 0.02883 seconds
Time After: 0.02901 seconds
Time Before: 0.03116 seconds
Time After: 0.03267 seconds
Time Taken: 0.00152 seconds
UPDATE session SET lastactivity = 1785334303, location = '/forums/private.php?do=newpm&explain=1&u=77005' WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.04796 seconds
Time After: 0.05094 seconds
Time Taken: 0.00298 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
