Time Before: 0.00144 seconds
Time After: 0.00210 seconds
Time Taken: 0.00065 seconds
Time Before: 0.00216 seconds
Time After: 0.00275 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00300 seconds
Time After: 0.00313 seconds
Time Before: 0.00406 seconds
Time After: 0.00699 seconds
Time Taken: 0.00293 seconds
Time Before: 0.00321 seconds
Time After: 0.01139 seconds
Time Taken: 0.00818 seconds
Time Before: 0.01329 seconds
Time After: 0.01374 seconds
Time Before: 0.01528 seconds
Time After: 0.01669 seconds
Time Taken: 0.00140 seconds
Time Before: 0.01263 seconds
Time After: 0.01686 seconds
Time Taken: 0.00423 seconds
Time Before: 0.02170 seconds
Time After: 0.02182 seconds
Time Before: 0.02367 seconds
Time After: 0.02491 seconds
End call of global.php: 0.026497840881348
Time Before: 0.02785 seconds
Time After: 0.02799 seconds
Time Before: 0.02998 seconds
Time After: 0.03138 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=77039', badlocation = 1
Time Before: 0.04356 seconds
Time After: 0.04393 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.042654991149902 seconds with 9 queries, spending 0.0087625980377197 doing MySQL queries and 0.033892393112183 doing PHP things.
