Time Before: 0.00158 seconds
Time After: 0.00223 seconds
Time Taken: 0.00065 seconds
Time Before: 0.00230 seconds
Time After: 0.00285 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00307 seconds
Time After: 0.00322 seconds
Time Before: 0.00391 seconds
Time After: 0.00666 seconds
Time Taken: 0.00275 seconds
Time Before: 0.00327 seconds
Time After: 0.01007 seconds
Time Taken: 0.00680 seconds
Time Before: 0.01223 seconds
Time After: 0.01248 seconds
Time Before: 0.01484 seconds
Time After: 0.01611 seconds
Time Before: 0.01168 seconds
Time After: 0.01629 seconds
Time Taken: 0.00461 seconds
Time Before: 0.02126 seconds
Time After: 0.02141 seconds
Time Before: 0.02354 seconds
Time After: 0.02482 seconds
Time Before: 0.02774 seconds
Time After: 0.02788 seconds
Time Before: 0.02981 seconds
Time After: 0.03132 seconds
Time Taken: 0.00151 seconds
UPDATE session SET lastactivity = 1784795873, location = '/forums/private.php?do=newpm&explain=1&u=77066' WHERE sessionhash = '6d76899e3772524375a2c635be997117'
Time Before: 0.04357 seconds
Time After: 0.05097 seconds
Time Taken: 0.00740 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
