Time Before: 0.01382 seconds
Time After: 0.01775 seconds
Time Taken: 0.00393 seconds
Time Before: 0.01786 seconds
Time After: 0.01823 seconds
Time Before: 0.01844 seconds
Time After: 0.01857 seconds
Time Before: 0.01934 seconds
Time After: 0.02327 seconds
Time Before: 0.01864 seconds
Time After: 0.02820 seconds
Time Taken: 0.00956 seconds
Time Before: 0.03433 seconds
Time After: 0.03479 seconds
Time Before: 0.03826 seconds
Time After: 0.03992 seconds
Time Taken: 0.00165 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.03352 seconds
Time After: 0.04022 seconds
Time Taken: 0.00670 seconds
Memory After: 2,261.836 KB
Time Before: 0.05687 seconds
Time After: 0.05703 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.07070 seconds
Time After: 0.07194 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
Time Before: 0.07950 seconds
Time After: 0.07967 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.08226 seconds
Time After: 0.08366 seconds
Time Taken: 0.00140 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
UPDATE session SET lastactivity = 1788935439, location = '/forums/private.php?do=newpm&explain=1&u=77207' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.10162 seconds
Time After: 0.10191 seconds
Memory Before: 4,287.578 KB
Memory After: 4,287.805 KB
