Time Before: 0.00159 seconds
Time After: 0.00236 seconds
Time Taken: 0.00077 seconds
Time Before: 0.00247 seconds
Time After: 0.00309 seconds
Time Taken: 0.00063 seconds
Time Before: 0.00332 seconds
Time After: 0.00343 seconds
Time Before: 0.00418 seconds
Time After: 0.00625 seconds
Time Taken: 0.00206 seconds
Time Before: 0.00348 seconds
Time After: 0.00962 seconds
Time Taken: 0.00614 seconds
Time Before: 0.01178 seconds
Time After: 0.01217 seconds
Time Before: 0.01497 seconds
Time After: 0.01614 seconds
Time Taken: 0.00117 seconds
Time Before: 0.01120 seconds
Time After: 0.01642 seconds
Time Taken: 0.00522 seconds
Time Before: 0.02430 seconds
Time After: 0.02447 seconds
Time Before: 0.02648 seconds
Time After: 0.02775 seconds
Time Before: 0.03061 seconds
Time After: 0.03074 seconds
Time Before: 0.03297 seconds
Time After: 0.03448 seconds
Time Taken: 0.00151 seconds
UPDATE session SET lastactivity = 1776605077, location = '/forums/private.php?do=newpm&explain=1&u=77223' WHERE sessionhash = '0072f2714e5608fd7a8a8d7024a3e041'
Time Before: 0.04867 seconds
Time After: 0.04906 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
