Time Before: 0.00439 seconds
Time After: 0.00619 seconds
Time Taken: 0.00180 seconds
Time Before: 0.00626 seconds
Time After: 0.00662 seconds
Time Before: 0.00681 seconds
Time After: 0.00696 seconds
Time Before: 0.00763 seconds
Time After: 0.00979 seconds
Time Taken: 0.00217 seconds
Time Before: 0.00702 seconds
Time After: 0.01434 seconds
Time Taken: 0.00732 seconds
Time Before: 0.01811 seconds
Time After: 0.01847 seconds
Time Before: 0.02078 seconds
Time After: 0.02203 seconds
Time Before: 0.01751 seconds
Time After: 0.02226 seconds
Time Taken: 0.00476 seconds
Time Before: 0.03212 seconds
Time After: 0.03228 seconds
Time Before: 0.04189 seconds
Time After: 0.04314 seconds
End call of global.php: 0.045394897460938
Time Before: 0.04832 seconds
Time After: 0.04847 seconds
Time Before: 0.05135 seconds
Time After: 0.05296 seconds
Time Taken: 0.00161 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=77370', badlocation = 1
Time Before: 0.07074 seconds
Time After: 0.07099 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.069552898406982 seconds with 9 queries, spending 0.0076999664306641 doing MySQL queries and 0.061852931976318 doing PHP things.
