Time Before: 0.01670 seconds
Time After: 0.02399 seconds
Time Taken: 0.00729 seconds
Time Before: 0.02411 seconds
Time After: 0.02458 seconds
Time Before: 0.02505 seconds
Time After: 0.02552 seconds
Time Before: 0.02636 seconds
Time After: 0.02884 seconds
Time Taken: 0.00248 seconds
Time Before: 0.02560 seconds
Time After: 0.03360 seconds
Time Taken: 0.00800 seconds
Time Before: 0.04089 seconds
Time After: 0.04130 seconds
Time Before: 0.04429 seconds
Time After: 0.04648 seconds
Time Taken: 0.00220 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.04018 seconds
Time After: 0.04675 seconds
Time Taken: 0.00657 seconds
Memory After: 2,261.836 KB
Time Before: 0.06937 seconds
Time After: 0.06957 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.08595 seconds
Time After: 0.08719 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
Time Before: 0.09714 seconds
Time After: 0.09728 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.09988 seconds
Time After: 0.10135 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
UPDATE session SET lastactivity = 1789120944, location = '/forums/private.php?do=newpm&explain=1&u=77373' WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.12089 seconds
Time After: 0.12118 seconds
Memory Before: 4,287.578 KB
Memory After: 4,287.805 KB
