Time Before: 0.02893 seconds
Time After: 0.04003 seconds
Time Taken: 0.01109 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.04016 seconds
Time After: 0.04087 seconds
Time Taken: 0.00071 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.04120 seconds
Time After: 0.04137 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.04229 seconds
Time After: 0.04461 seconds
Time Taken: 0.00232 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.04143 seconds
Time After: 0.04871 seconds
Time Taken: 0.00728 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.05424 seconds
Time After: 0.05470 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.05640 seconds
Time After: 0.05765 seconds
Memory Before: 2,908.320 KB
Memory After: 2,908.180 KB
Time Before: 0.05353 seconds
Time After: 0.05788 seconds
Time Taken: 0.00435 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.250 KB
Memory Used: 132.648 KB
Time Before: 0.12164 seconds
Time After: 0.12181 seconds
Memory Before: 3,655.805 KB
Memory After: 3,656.320 KB
Time Before: 0.31174 seconds
Time After: 0.31301 seconds
Memory Before: 4,133.352 KB
Memory After: 4,133.945 KB
Time Before: 0.36003 seconds
Time After: 0.36021 seconds
Memory Before: 5,197.547 KB
Memory After: 5,325.891 KB
Time Before: 0.36723 seconds
Time After: 0.36870 seconds
Memory Before: 5,481.227 KB
Memory After: 5,610.828 KB
UPDATE session SET lastactivity = 1773355553, location = '/forums/private.php?do=newpm&explain=1&u=77429', badlocation = 1 WHERE sessionhash = 'eaa8a3ac54cff5a66f956999e9bca4a9'
Time Before: 0.40250 seconds
Time After: 0.40298 seconds
Memory Before: 5,998.055 KB
Memory After: 5,998.250 KB
Memory Used: 0.195 KB
