Time Before: 0.02516 seconds
Time After: 0.03616 seconds
Time Taken: 0.01101 seconds
Time Before: 0.03625 seconds
Time After: 0.03670 seconds
Time Before: 0.03689 seconds
Time After: 0.03704 seconds
Time Before: 0.03779 seconds
Time After: 0.04046 seconds
Time Taken: 0.00267 seconds
Time Before: 0.03711 seconds
Time After: 0.04443 seconds
Time Taken: 0.00732 seconds
Time Before: 0.05699 seconds
Time After: 0.05744 seconds
Time Before: 0.05980 seconds
Time After: 0.06105 seconds
Time Before: 0.05636 seconds
Time After: 0.06124 seconds
Time Taken: 0.00488 seconds
Time Before: 0.10772 seconds
Time After: 0.10785 seconds
Time Before: 0.13218 seconds
Time After: 0.13350 seconds
Time Taken: 0.00132 seconds
End call of global.php: 0.13570809364319
Time Before: 0.14423 seconds
Time After: 0.14437 seconds
Time Before: 0.14665 seconds
Time After: 0.14811 seconds
SET lastactivity = 1784833798, location = '/forums/private.php?do=newpm&explain=1&u=77610'
Time Before: 0.16756 seconds
Time After: 0.16782 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
Page generated in 0.16661906242371 seconds with 9 queries, spending 0.0082919597625732 doing MySQL queries and 0.15832710266113 doing PHP things.
