Time Before: 0.00274 seconds
Time After: 0.00385 seconds
Time Taken: 0.00111 seconds
Time Before: 0.00392 seconds
Time After: 0.00433 seconds
Time Before: 0.00456 seconds
Time After: 0.00470 seconds
Time Before: 0.00556 seconds
Time After: 0.00913 seconds
Time Taken: 0.00356 seconds
Time Before: 0.00478 seconds
Time After: 0.01366 seconds
Time Taken: 0.00888 seconds
Time Before: 0.01643 seconds
Time After: 0.01687 seconds
Time Before: 0.01839 seconds
Time After: 0.01962 seconds
Time Before: 0.01565 seconds
Time After: 0.01986 seconds
Time Taken: 0.00422 seconds
Time Before: 0.02586 seconds
Time After: 0.02600 seconds
Time Before: 0.02853 seconds
Time After: 0.02983 seconds
End call of global.php: 0.032799005508423
Time Before: 0.03414 seconds
Time After: 0.03435 seconds
Time Before: 0.03654 seconds
Time After: 0.03798 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=77659'
Time Before: 0.05041 seconds
Time After: 0.05072 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.049491167068481 seconds with 9 queries, spending 0.0091695785522461 doing MySQL queries and 0.040321588516235 doing PHP things.
