Time Before: 0.01880 seconds
Time After: 0.02310 seconds
Time Taken: 0.00430 seconds
Memory Before: 1,157.773 KB
Memory After: 1,182.891 KB
Time Before: 0.02320 seconds
Time After: 0.02441 seconds
Memory Before: 1,182.828 KB
Memory After: 1,183.836 KB
Time Before: 0.02464 seconds
Time After: 0.02478 seconds
Memory Before: 1,184.422 KB
Memory After: 1,184.945 KB
Time Before: 0.02573 seconds
Time After: 0.02832 seconds
Time Taken: 0.00259 seconds
Memory Before: 1,187.547 KB
Memory After: 1,188.469 KB
Time Before: 0.02485 seconds
Time After: 0.03225 seconds
Time Taken: 0.00740 seconds
Memory Before: 1,184.164 KB
Memory After: 2,265.219 KB
Memory Used: 1,081.055 KB
Time Before: 0.03851 seconds
Time After: 0.03897 seconds
Memory Before: 2,758.023 KB
Memory After: 2,758.641 KB
Time Before: 0.04206 seconds
Time After: 0.04327 seconds
Memory Before: 2,770.195 KB
Memory After: 2,770.055 KB
Time Before: 0.03771 seconds
Time After: 0.04351 seconds
Time Taken: 0.00580 seconds
Memory Before: 2,750.172 KB
Memory After: 2,883.414 KB
Memory Used: 133.242 KB
Time Before: 0.08096 seconds
Time After: 0.08112 seconds
Memory Before: 3,436.539 KB
Memory After: 3,437.055 KB
Time Before: 0.09658 seconds
Time After: 0.09781 seconds
Memory Before: 3,524.336 KB
Memory After: 3,524.930 KB
End call of global.php: 0.100665807724
Time Before: 0.10992 seconds
Time After: 0.11013 seconds
Memory Before: 4,162.242 KB
Memory After: 4,162.672 KB
Time Before: 0.11283 seconds
Time After: 0.11427 seconds
Memory Before: 4,443.805 KB
Memory After: 4,445.492 KB
SET lastactivity = 1785311633, location = '/forums/private.php?do=newpm&explain=1&u=77766'
Time Before: 0.13372 seconds
Time After: 0.13403 seconds
Memory Before: 4,922.117 KB
Memory After: 4,922.320 KB
Memory Used: 0.203 KB
Page generated in 0.13271880149841 seconds with 9 queries, spending 0.0089528560638428 doing MySQL queries and 0.12376594543457 doing PHP things.
